melrosedave said:
Hey guys I'm new to the forum. I've got an IZip Via Rapido bike with a 24v 10AH system. The range is very limited since I live in a very hilly neighborhood. What are my options if any to upgrade either the battery and or the system to gain more range. I'm fine with the power but if more can be gotten at the same time that would be a nice bonus. Thanks very Much.
Hay melrosedave,
first of all welcome!!
it really depends on your budget & what your looking for
If your not happy with the range, but happy with the speed, buy a new battery's eighter lipo or lifepo4
e.g. http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=16226
4 of those will give you 28v x 16ah, you'd also need to buy a charger, plus get a wire harness from "icecube57"
or you could get a quote from "cellman" for a an equivalant lifepo4 battery, more $$$ but better longevity.
if you want top go faster, you'll need a more powerfull controler, say a 36v/48v controller, if your comfortable with electronics/soldering, it's a no brainer really a decent one can be picked up for under $100, talk to "lyen", but i'd check with the community first, to make sure your hub motor is capable, it should be, but no promises.
you'll need a new battery, again look at option one but your gonna need 36 or 48v 16ah
the most exspensive, but best, would be to buy a complete kit, say a magic pie 3 from bmsbattery, then simply add a battery from elsewhere, wouldn't recomend buying a battery there better can be had, for the same price.
whatever you do, i'd recomend reading alot b4 you take the plunge, i made a few mistakes along the way that cost me A few hundred dollars, i'm by no means the most experienced, but i've got a few months experience, that i wouldn't mind sharing, hit me up with pm's, ill point you in the right direction.
