ngant17
1 W
Jump starting dead 60v lithium ion batteries. Caveat. Please note.
I just want to put out a warning for anyone trying to do a 'jump-start' trick to revive a dead lithium ion battery. I just tried out that technique to try on my 60v 4ah Greenworks battery. Although it seemed to be relatively harmless and possibly help the older battery when I hooked it in series to a lower amp-hour 60v battery (2ah).
However the real fireworks happened when I tried jumpstarting the old battery to another one of same 60v, 4 amp-hours. For whatever reason, it totally melted the contacts and clips I was using to connect both batteries, in addition to producing a intense shower of sparks from the old battery. Therefore, based on personal experience, using the same amp-hours between the 60v 4ah batteries for jump starts is a serious hazard and I would discourage anyone from trying this so-called “quick fix” to resurrect dead lithium ion batteries.
Tearing down the batteries and isolating bad cells is the smart and safe way to do rebuilds. And this specialist job should not be taken on by amateurs, which includes me.
