Looking to sell my E-Bike battery building equipment and all the supplies you need to build your own battery's.
Asking $400 for everything. Shipping would be on you.
Here is the list:
1. (1) KeenLab K-Weld kit w/ housing. Used works perfect.
2. (1) KeenLab K-Weld kit w/ housing. New in box never used. Had for a spare.
3. (2) Turnigy Nano-tech 5.0 Lipo Battery. 3s, 11.1v, 5000mah, 65-130c Discharge. Used, works fine as primary supply power.
4. (1) Turnigy Nano-tech 6.0 Lipo Battery. 3s, 11.1v, 6000mah, 25-50c Discharge.
5. (1) Liperior 5.2 Lipo Battery. 3s, 11.1v, 5200mah, 150c Discharge.
6. (1) Tenergy TB6B Multi function balance charger for Lipo power supply battery's.
7. (1) Zanflare C4 Li-Ion single battery charger for 18650 cells. 21700 will also work too. Charges (4) battery's at a time.
8. (2) Daly 14c, 48/52v, 30a BMS. New.
9. (1) Daly 14c, 48/52v, 50a BMS. New.
10.(2) Vruzend 14c, 52v, 30a BMS. New.
11. 21700/18650 Nickel Belt Material. New.
12. 21700/18650 Insulating rings for pos terminals. New.
13. (57) 21700 Samsung 50E Cells. New unused.
14. (8) 18650 Sanyo GA Cells. New unused.
15. Spare Vruzend Cell Holders and misc wiring and plugs.
Been making batterys since 2018 and if you want to repair or make from scratch your own custom designed battery packs this is the stuff you need to do it safely and efficiently.
Thanks for looking.
Im located in San Diego Cal. USA
Here is the list:
Thanks for looking.
