thoroughbred
I have started to wonder if using a Motenergy split stator motor would make things easier to reach the 200# powerful dirtbike result utilizing somewhat affordable battery and controller offerings. In my digging I found that DanGT has the same thoughts! :thumb: https://endless-sphere.com/forums/viewtopic.php?t=53617&start=25
In learning some of the capabilities of the nucular and mobipus controllers, i'm wondering If I could get some "clutch" functionality by playing one controller against the other. Pull a lever or push a button and one controller is now regenerating the other. NOt sure how any of that would work but I will have the ability to use two separate batteries if needed. Lots of ramifications to consider. The throttle, motor temp and halls signal would be the only things shared, potentially. :?
