Kelly Controller KLS7230S (Sold)
dchgarage
🧲 New user
Canary Islands
Sold!
Hello,
I am selling one Kelly Controller KLS7230S purchased directly to QSmotor. It is new and unused. I purchased it for a project that I couldn`t start.
Price : 130€.
International shipping cost from Canary Islands (Spain): 35€
QUICK OVERVIEW
To 3K-5KW motor,KLS controller is supposed to reduce the noise of BLDC motor,especially for hub motor.The BLDC motor must be based on 3 hall sensors.
Configuration:
•Controller supply voltage range: PWR, 18V to 90V for controllers rated equal or lower than 72V.
•Motor Current Limit, continuous: 120A ,depending on the model.
•Motor Current Limit, 10 seconds boost: 300A ,depending on the model.
•Supply Current, PWR, 30mA Typical.
•Frequency of Operation: 20kHz.
•Standby Battery Current: < 0.5mA.
•5V Sensor Supply Current: 40mA.
•Configurable battery voltage range, B+. Max operating range: 18V to 1.25*Nominal Voltage of Battery.
•Standard Throttle Input: 0-5 Volts(3-wire resistive pot), 1-4 Volts(hall active throttle).
•Throttle Input: 0-5 Volts. Can use 3-wire pot to produce 0-5V signal.
•Main Contactor Coil Driver<2A.
•Full Power Operating Temperature Range: 0℃ to 70℃(MOSFET temperature).
•Operating Temper ature Range: -40℃to 100℃ (MOSFET temperature).
•Max Battery Current : Configurable.
