Mattmatthews
- Joined
- Apr 22, 2021
- Messages
- 3
Please help I don't want to die it's my second day with the bike it is a lcd8 csc rear hub 1500w kit with 52v triangle, I accidentally did a factory reset with c10 or 12 or whatever I dont know if that is why after a long deceleration I get on the gas and my motor spins backwards for a split second, it messed up my rear swing arm this last time because I was going a bit faster then the first time it happened also I put my pas sensor on the left side using a spring and washer to hold it in place and I flipped the mag wheel so it would spin in the correct direction please help
