john33
100 µW
Hello people,
After 2 years of almost no problems my dit e-bike is having issues.
My diy bike is fitted with a KT36-SVPR-LCD controller and LCD7 display.
The battery is a li ion bidon shaped 36v.
Last week i saw that the display was fading (dark in the morning, head/tail Light on) so i pressed the middle button 2 times to see the voltage..... It showed 48 volts and rising up to 58 volts.
The higher the voltage the more the display was fading until nothing showed, just the backlight.
The controller kept working, but suddenly al went black.... A power down and restart gave it a restart and i could go on but that happened 2 times again later.
I took the system apart, and measured a few things.
Voltage from a fresh charged battery is about 40 volts, at the battery terminals, but also at the connector to the display.
When i connect the display and power up the system the display fades a bit, I press the middle button 2 times to see the voltage,.....
52 volts and rising.... Up to 58.
And its fluctuating, 53,7 54,2 57,8 and down to 55 etc etc ..
What the h*ll is happening here, and how do i solve this?
