kt36zws-lcd pas and speed sensor not working?
wiilegend
belgium
my motor works when use the walk assist but I don't get speed or pas, both cable have been lengthend using a cable and soldering. to work in a velomobile what could be the problem the lcd display lcd 1
thanks in advance
You need to check the settings to see whether they're enabled, but I'm not sure that the LCD1 gives access to the necessary settings. For testing with the throttle, you should start with C4=0 and P4=0. The pedal sensor has to be set with C1. Download a manual for LCD3 to see the settings. All the KT LCDs give access to all the main settings. Only LCD1 is restricted.
The LCD1 only has five P settings and no C settings, My LCD1 bike is in storage, so I can't check my settings, I think you need P3 and P4 both set to zero, P1, P2, and P5 don't affect throttle/PAS operation.
  • LCD1 Manual.pdf
thanks guys,
have been able to fix the speed sensing issue by using the motor speed sensor however pas does not work should I buy a new display or are there other solutions?
