seba240698
New-ish here
- Joined
- May 10, 2019
- Messages
- 46
Hi, I bought a KT36/48ZWSRT-LCD-CAD controller for brushless motor via online platform. See attached diagram.
The package came with a LCD (LCD3, see attached user manual) and a PAS using a split magnetic disc and a KT D12L cable.
After I installed them into my e-bike, everything worked fine except that the motor ran at only 19W as shown in the LCD, even though the controller is rated at 250W. The hub motor in my e-bike is rated at 250W/350W and it was running well 2 weeks ago, except the old LCD was giving me intermittent problems (the screen would blank off and the display was distorted due to water seepage caused by rain). My old controller was doing well although it was already 4 years old. I was very worry that if I were to buy just a LCD, it might not be compatible to my old controller, that was why I bought a whole set (LCD + controller + PAS).
I communicated with the seller, he merely e-mailed me the KT LCD3 user manual which I managed to read all of it yesterday. I changed the motor power (C14) and maximum allowable current (C5) settings to maximum but still motor only run at 19W. I do not understand some of the settings like P2, wheel speed pulse signal setting and C1, power assist sensor and parameter select setting.
I was thinking to buy another controller but then worry that it may not be compatible with KT LCD display.
Do you suspect that this problem is due to LCD setting only or are there other possible cause of it?
Thank you.
Thank you.
