woahdae
My mom (~70yo) wants to get an ebike with a Shimano Nexus 5E IGH (this Electra Townie), but the lowest gear is 33.92 gear inches. The mid drive motor is 50nm, 250w, so pretty mild, which is great honestly to give her some extra range. There's a couple hills around her town that I think she still probably won't be able to do though.
Really, it's the perfect bike for her, except for maybe the gearing. So I'd like to do some preliminary planning on putting in a bigger sprocket on the IGH.
Sheldon Brown's site says this about Shimano IGH sprockets:
I see what he means about the 9 splines, and I can find some 3rd party 40-tooth single cogs, but anything in the 34t range is part of a cassette. He makes it sound like they're relatively available.
Anyone care to break down Sheldon's wisdom a bit more? I can dremel splines no prob, but I don't see where I'm supposed to buy anything suitable.
It is fairly easy to modify any Shimano cassette sprocket that doesn't have a built-in spacer. These are available from 14-34 teeth. Shimano cassette sprockets have the same internal diameter as those used with internal gear hubs, but have 9 splines instead of 3. With a suitable grinder, 6 of the splines need to be removed, and the corners of the remaining three rounded off
