By "battery" do you mean actual battery stats, or just a basic pretty bar-meter like a celphone/etc?
What voltage system is it for?
If you want actual battery stats, how much current (amps) and power (watts) do you need to monitor?
Those will be needed to help you pick a compatible unit.
For MPH, do you want a dial gauge, or just numeric?
Do you want it to run from a wheel speed sensor you already have?
If so, what type of sensor is it, and what signal does it output?
If not, what kind of sensor would you prefer that it use? Some can sense a hubmotor's motion using the hubmotor sensors or phases, and some require a different kind of sensor, either mounted to the frame with magnets on a wheel, or some other type.
By "blinkers", do you mean a light or other indicator that shows you your lights are blinking? Because...you can generally *see* those doing that, directly, on a motorcycle or other bike.
If you do need this function, do you want one that has a single indicator simply showing there is flashing going on?
Or do you want one that has separate indicators showing which lights are flashing?
The more detailed and specific your information is, the better we can answer your questions.
Very short, general answers and posts don't really help us help you nearly as well as longer detailed answers, questions, and posts.
