LCD-M5 display controls
smitel
100 µW
All manuals I found for the LCD-M5 on my Shengmilo MX02S are close to incomprehensible.
So I compiled my own.
Code:
= Walk assist =
Controls: Hold [DOWN] while standing still
= Cruise mode =
Controls: Hold throttle and [DOWN]
Support without holding throttle or pedaling
Increasing PAS in Cruise mode is only in effect while pedaling.
When pedaling stops it goes back to first PAS set.
Decreasing PAS in Cruise mode has no effect
= P-Setting mode =
Controls: Hold [UP] and [DOWN]
= Switch multifunction display =
Controls: Quickly depress [POWER]
Cycles multifunction through ODO, TRIPA, VOL, CUR, TM.
= Switch speed display =
Controls: Hold [UP] and [POWER]
Cycles between Max, AVG and curr.
= Switch lamp =
Controls: Hold [UP]
Cycles between "Manual" and nothing.
No effect on my MX02S
= b007 mode =
Controls: Hold [DOWN] and [POWER]
Shows b007 in multifunction area.
No idea what it does.
You can still get into setting mode but you cannot see what you are setting because it's overwritten with b007.
Holding down and power again shows "E 010" for a moment before going back to now.
