Allex
Guys, I would like to connect a digital meter to my batteries. Question is how I do this.
I bought few of these and they burned up when I tried
http://www.ebay.com/itm/Red-LED-LCD-Display-Digital-Voltage-Volt-Meter-Voltmeter-Panel-DC-0V-99V-New-/270982507618?_trksid=p5197.m1992&_trkparms=aid%3D111000%26algo%3DREC.CURRENT%26ao%3D1%26asc%3D14135%26meid%3D5382886104856329379%26pid%3D100015%26prg%3D1085%26rk%3D1%26sd%3D270982507618%26
Feature:
Range: DC 0-99V
Refresh rate: about 500mS / times
Maximum input: <1.2 times the range
Accuracy: 1 %(+/- 1 digit)
Power Supply: DC 4.5-30V
Operating temperature: -10°c~ 65°c
Dimension: Approx. 30x16x11mm
Wiring:
Red Wire: Power Supply +
Black Wire: Power Supply -, Measure -
Green Wire: Measure +
Power cannot be reversed, otherwise it will burned the module
First of I tested them with a 9V battery
Battery PLUS to Panel red wire
Battery PLUS to panel green wire
Battery MINUS to Panel black wire
Test went fine
Than I connected with same principal but to a 84V lipo battery and the components on the LCD circuit board burned up.
What am I doing wrong here (something with powersupply max Voltage 30V)?
Feature:
Range: DC 0-99V
Wiring:
Test went fine
