Leaf controller and Rev?
krelle52
10 µW
Hello
I bought two controllers from "Leaf Motor" which should have the following functions:
EABS System
1 + 1 Assistance
Idle Running Protection
Dynamic Power Lock System
Motor Shaft Lock Protection
Power Tube Protection
Cruise Speed ​​Control
Self-check Protection
Speed ​​Limit
Remote Control Anti-Theft
Support Forward and Reverse Control
Three-Speed ​​Gear Change
I've almost got everything to work, but I lack the most important. To have one of the controllers running backwards. I thought it was the two gray wires which could be connected together, but no - it was the speed limit. So I opened the controller and looked at the PCB. There was not as I hoped, a jumper which just had to be moved. But there were several unused option points for connectors on it's PCB. I took a picture, but it is slightly out of focus. So here's a list of only the unused:
XH (The gray wires which were the speed limit, was soldered to XS)
EBS (This may explain why I can not get the regen braking to work??)
DC
BKH (I think it is for brake high?)
SPBK
60/120
FYB
LDS
3S (I think it is 3 speed gear change?)
DS
FD
YX (I thought this option was the reverse. .. But no, nothing happened)
PCB is marked with YL08E-FPCB
So if there is anyone who knows what all those abbreviations mean or have an idea. Then I would love to know. For I have no idea which one I need, to reverse the direction of the motor.
17-07-20011
Me again, I forgot to ask:
On 3 phase ac motor you can swap two wires to get motor to run the other way (I'm an electrician) Is that a possible solution with a dc hub controller with hall sensor?
Krelle52
You will need to reverse two wires in the power to the winding and also two in the wires to the halls.
Try to reverse the same two colors on each to see if it works well.
Stephen
