Nepi and SpinningMagnets, thank you for your excellent and thoughtful answers! Very appreciated.
Now I've got a question about customization of these motors. Obviously you're not a vendor, but since you have investigated already and have purchased, you may know. Because the product page gives no hints as to customizations (it doesn't even invite you to ask), but in emails posted here, the vendor made it sound like they can make a one-off of just about any modification, while still managing to be vague (for instance, we still don't know how to ask for motor winds using anything other than a rated
no-load/kV
RPM .
You may not know, but someone may, and since interest was already raised by someone else here: what about wide axles, say for fat bikes. Many fatbikes these days have 190mm dropouts, so I'm wondering if it's known if there's a suitable wide axle width. Sounds like wide-stator DD motors like this would actually do better with more width to play around width. The 135mm dropout width, in my research, seemed to be the biggest design challenge.
And to fully come around to Fat Bike kits, manufacturers are going to have to start making 32-hole hubs, as virtually every fatbike I've seen for sale on the net is 32H. The big exception is the Mongoose models. Mongoose's 36-spoke thing makes me almost want to abandon this Quixotic thing of trying to put a square peg in a round hole, er, a hub motor in a fatbike, and just say F it, I'm spending $217 on an overly-heavy, entry-level bike where I assume almost every component needs to be replaced or worked on. I can work around the hole-cout by getting a rim and lacing it. It's the axle I'm most-concerned about. (And one of the easiest things for the mfr to change).
Oh, and speaking of which, Nepi how did you do with using a disk brake on this? (I assume that's what you're using.) Having not actually done a DIY kit yet, I'm trying to take it all in.
I for one will say I found
cwah's sinewave controller as very interesting (
cwah, if there's a thread where you've discussed it, pleases let me know). That's the first decent/I'll say "normal"-looking, low-cost sinewave controller I've seen. I hope this becomes a trend. For me, the visual obviousness of this motor is one of its biggest downsides. But at least I could sneak up on people.
You know what, I nearly did that recently with my little massmarket hubmotor bike. 2 neighbors twere alking near the road. The one with his back turned to me, never would've known I was there, had the other guy not seen me coming, and nodded in my direction once I passed, to get his friend to 'check this guy out'. Enjoying the silence is the #1 appeal of e-bikes for me, over combustion.
