I know y'all have missed me...
I've had a hard time formulating this question, but when I discovered my fatbike rear wheel was dished (although I have a symmetrical frame), it dawned on me that a Leafbike motor may not line up properly to a disk brake on a fatbike, and maybe not even with the freewheel/chainline. In other words, the disk might be too far in to reach the caliper at the frame. And I don't know if about the gears--too far out would be worse than too far in (I'm not sure which would happen), but how do I know that's going to line up properly, either?
My fatbike uses a common SRAM BB5 disk brake, but of course in that wide frame, the mount on the LeafBike motor is probably going to be too far in. I had not thought about this, nor seen discussion of it.
My other thought was that people with 190mm and 215mm dropouts are going to have even different line-up points for the disk brake mount.
To complicate matters, my bike has a 10-speed cassette.
For buyers with fatbikes, how would one go about ordering one from LeafBike, so that brake and freewheel line up properly?
This is one of several reasons I think I am going to go with a fat mac after all. The fatmac looks like it has a large spacer for the disk brake. Plus, the "shoulders" are already going to be correct for a 170mm dropout frame, with no special requests. Paul said the fatmac could be adapted back to a 135mm dropout frame, but only with a new axle, apparently because of those shoulders. However, I don't know what would happen with that big brake spacer.
LeafBike actually does sell a thick brake spacer, but frustratingly, they don't even put the width of it in their description! Em3EV also sells narrow spacers for fine-tuning. I was thinking that with a combination of these, it might be possible--but it's not clear to me how to calculate exactly how much spacer you'd need. And it's not indicated if longer screws come with thick LeafBike spacer anyway, or where you'd get screws/bolts of proper length. I also wasn't sure if it was best to space the rotor towards the caliper, or possibly find a way to bring the caliper in towards the rotor, or a combination of both. So in short, I'm not sure how disk brake and possibly freewheel/cassette spacing would work on this, to ensure that the tire be centered, with everything lining up?
EM3EV has now gotten the quality 80mm rims in. They also know how to dish wheels, and this is not intimidating for them. Plus I hear their spoke jobs are pretty good. And communication with Paul is as good as communication is bad with LeafBike. Turns out Paul IS in fact British (living in China), which I always thought, but couldn't remember why I thought that. So that explains his fluency (and probably some other things).
Whether I get a LeafBike or not at this point I'd still like to know about this line-up, to help me and others understand how to work this on fatbikes, or if it's even a reasonable venture.
