auraslip said:
Can I leave the charger plugged into the battery while riding?
Probably. Does your setup do regen? If so, you'll want to make sure the charger can take the higher-voltage input when it is unpowered. *or*, you can add a relay that has it's coil powered by the charger so that the charger is only connected when it is plugged in and powered on. (even easier if there is a power LED on the charger, as you could tap that to power the relay coil, if you use a low-voltage-coil relay).
Can I leave the controller and dc-dc converter plugged into the battery while charging?
What is the voltage the charger puts out at maximum? (this means, without being plugged into a battery, as that could be significantly higher that way. If the battery internal connections failed or something, the full charger voltage would feed into anything else still connected)
What is the maximum voltage the controller can take?
What is the maximum voltage the DC-DC can take?
As long as the charger doesn't put out more than they can take, it'd be fine.
FWIW, at least some powerchairs have such a relay system on them that disconnects the battery from the controller/etc while the charger is plugged in, though it is to prevent unintended operation that would rip the plug out of the wall rather than any electrical protection.
