Lifan e4 charger needed
Gavin GJ
New Zealand
Hi. I have a lifan e4 but no charger. Does anyone know where I can order one, aliexpress or some such? It's a 60v battery I believe. Are Chargers interchangeable or very specific to a make/model? Photo of charging port attached.
Thanks
Gavin
Did you try contacting Lifan?
Lifan Motors
You could use a generic aftermarket charger, but you would probably need to replace the charger plug (or add a second connector). The extra small pins on the charging plug may carry data that the BMS needs to allow charging, so this might not work.
Yes I have emailed lifan, a genuine charger would be the best option but no answer from them as yet. Also keeping an eye out on Facebook etc for a used one.
There seems to be remarkably little info on these scooters online. Unsure why.
Thanks
Gavin
