m_cremers
Hi all,
I'm new here and have spent the last weeks digging through this forum in search for an answer for my particular problem.
Im not sure, but this might be a total noob question with am obvious answer.
So here's the thing. I have an Ortler EC700 eBike which has a motor that I can find next to no info about named "G1 center drive" (no make or model other than this)
This motor has two plugs, one is the standard powercord and one that I suspect might be the torque sensor. Ive attached a photo of that plug.
I have been looking like crazy to find a matching controller + display.
The original were a lishui type controller with a rohs sw102 display. That stopped working.
Bought a new display (windmeile kt lcd4)
That turns on, but does't receive a soc signal and makes the controller flash a red led whenever I turn it on.
Then I bought a kt controller, hooked it up to the battery and that does give an SOC signal. It has the main power julet connector for the motor but...and this the point of my long winded story... It does not have a wire to hook up the suspected torquesensor from the motor.
Result. Nothing happens when I hook it all up. The main power plug does do something as trying to turn on power assist on the display, the motor gives a very soft click. But other than that nothing. I've attached a pedal and turning it does not activate the engine in any way.
My amateur conclusion is that this extra plug coming from the engine is vital. My original lishui controler has a seperate wire to hook it up, but I havent found any of the dozens of other controler for sale online that have an extra wire like this.
I'll attach photo's of
The original controler
The extra wire coming from the motor
The motor itself.
I really hope anyone can advise me on this matter.
I am hoping to find out:
- what the extra motor cable is
- what controllers exist that have this connection
- what display might match with the original controler (in case thats still working)
- anything about this situation that I am missing or approaching wrong.
I really really appreciate any help as I am stuck and this has rendered my rather pricey bike completely useless.
Thank you!!
The motor itself.
Thank you!!
