johnnyz383
I want to run by something for the readers of this forum. I had a 48 volt system consiting of 18650 lifepo4 1400 mah batteries. I wanted to increase the voltage to 72 so bought 96 lifepo4 batteries from china. I finally hooked everything up and the sag was incredible....(i have a Crystalyte hs3540 hub motor on a custom trike)...nominal voltage was 72 volts....at full throttle, it sagged to 59 volts....after a couple of minuets of testing something happened and i was now down to 67 volts nominal. I took it apart and 16 of the group of batteries were down to about .3 volts.
Earlier when charging the whole battery pack using a singalab bms, it would immediately go past 4 volts only on a specific series of batteries (the new ones). I initially thought there was something wrong with the BMS so bypassed it and simply hooked up a 84 volts charger to neg and positive and again this row spiked in voltage and the others stayed the same so now im thinking that in fact there was something wrong with some of these junk batteries. When it did go past 4 volts i heard a faint popping noise. I initially inspected the batteries but they appeared fine. Voltages checked out too..after this ride i find that after taking them all apart they are leaking something, and voltages near zero. When i go to charge individually they initially come up to 3 volts but off the charger immediately start going down in voltage to almost zero HERES THE QUESTION....if a battery is shorted would it display this behavior?...and if there was something wrong with them maybe the BMS simply couldnt bleed off the high voltage fast enough and the battery kept rising in voltage while the others remained the same??
Thanks
John
Thanks
John
