markz
100 TW
I've been looking at these pouches. Can I just solder onto the tabs?
Has anyone else bought ANY cells from them, and what was the throw-away rate?
High C-Rate 10Ah LiFePO4 Cells
https://bmsbattery.com/ebike-battery/625-high-c-rate-10ah-lifepo4-cells-battery.html
Condition New
High C-Rate 10Ah LiFePO4 Cells.
More info
1. Nominal Voltage:3.2Volts.
2. Dimension: 8.4x60x260mm
3. Capacity: >10Ah.
4. Maximal Charge Current: 2C(20Amps).
5. Maximal Continuous Discharge C-Rate: 5C(50Amps).
6. Maximal Discharge C-Rate: 10C(100Amps).
7. Overvoltage Protection: 3.65±0.05Volts.
8. Undervoltage Protection: 2.0Volts.
9. Lifecycle: 2000Cycles.
10. Weight: 300Grams.
11. Impedance: ≤8mΩ.
12. Chemical: LiFePO4.
