Bouteille51
Hi all,
I am in the process of planning my first ebike build and I would need some advice regarding the "cheap" battery packs that can be found on ebay.
It will be mostly used for home-to-work commute and I would like to favor the number of cycles I can get out of my battery pack, hence my choice to use lifepo4 technology.
Ideally I would go for a ping or em3ev battery pack but I am not sure yet if I am going to stick to the ebike solution, so I'll go with a cheaper option first (I realize that one can be lucky or not with it).
In the cheap options found on ebay I am trying to compare two different packs: the "blue" one and the "grey" one, both 48v and 20ah... see attached pictures taken from ebay listings.
The BLUE one with this 'sun-ebike.com' sticker seems to be the most 'common' one. I guess this is what has been sold sold for years by sun-thing and other ebay accounts of the same company, correct ?
I saw a lot of comments on these packs here and I would be ok to try ordering a pack from them (delivery time is not a problem).
I recently realized that the GREY one is also sold by the same guys (correct me if I'm wrong) but has slightly different characteristics (see a copy-paste of both below). The price is also slightly higher but nothing significant.
I am wondering whether it is just a packaging (and marketing) difference or if there is a real technology difference between them. Do you know if the pouches/cells or BMS are indeed different, and if the stated charge/discharge rate difference are real ?
I am also surprised about the minimal discharge voltage claimed by both packs: one seems to cut off at 45v while the other one seems to cut at 41-42v...
The BMS seems accessible in the grey pack but is this a decision maker ? Probably if I need to troubleshoot the battery at some point...
I have also seen other packs with grey tape and the BMS in a grey plastic box, but much more expensive... any thoughts ?
Thank you for your help !
Description for the BLUE pack :
High-capacity 48V20AH LiFePO4 battery parameters:
Discharge cut-off voltage: 45V
Rated discharge current: 30A
Instantaneous maximum discharge current: 50A
Rated charging current: 5A
Maximum charge current: 8A
Battery pack size: 16*17*27cm
Battery pack weight: 8.9kg
Battery pack capacity: 20AH ± 1%
Charge cut-off voltage: 58.5V
Description for the GREY pack :
Nominal Voltage 48V
Voltage Range 42 - 58.2V
Rated Capacity 20Ah
Over-discharge Voltage 2.100V( Any cell)
Over-charge Voltage 3.900V( Any cell)
Charge Voltage 60V
Open Voltage after fully charged 51V~57V (1 hour after being fully charged)
Maximum Charge Current 10A
Estimated Charge Time @5 A About 4 hours
Discharge End Voltage 41.0-42.3v
Maximum sustained work current 30A
Maximum Discharge Current 45A
Over Protection Current 60A
Temperature Rise ≤25℃
Operation Ambient Temperature
Charge 5~50℃
Discharge -20~50℃
Cycle Life ≥1200times(Cycle@23°C,0.5C ,100%DOD)
Storage Temperature Range Less Than 1 Year: -20~25°C
Less Than 3 Months -20~40°C
Weight About 8.2kg
Size 26*15*12 cm
Colour Epoxy board packaging + silver tapes (silver)
This battery is include BMS AND 5A CHARGER.
Nominal Voltage 48V
Rated Capacity 20Ah
Charge Voltage 60V
Charge 5~50℃
Discharge -20~50℃
Weight About 8.2kg
Size 26*15*12 cm
