robb
Hi I recieved a cammy-cc 20 amp hour 24volt lifepo4 battery about 2 months ago http://cgi.ebay.co.uk/LiFePO4-24V-20AH-Electric-Scooter-E-Bike-Battery-power_W0QQitemZ170326000698QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item27a838843a&_trksid=p3286.c0.m14&_trkparms=72%3A1688%7C66%3A2%7C65%3A12%7C39%3A1%7C240%3A1318%7C301%3A0%7C293%3A1%7C294%3A50 . Seemed fine taking me about 20 miles before cutting out. I realise now I should have not let it drop charge enough to cut out but too late now
A few weeks ago something must have shorted in the controller while I was not using it, I must have forgotten to switch of the isolator switch, and when I tried to use it a day or two later found that the 25 amp fuse had blown, the battery was completely discharged and the brushed dc motor had burnt out. Luckily I had been given the motor off an ancient e bike a neighbour was throwing in a a skip. The battery seemed to charge ok and yesterday I fitted a a new 360 watt cyclone.But a few seconds after I twisted the throttle the bms cuts out. It even cuts out with just a tiny bit of throttle but does not cut out with no load and the back wheel off the ground.Tried it without the bms for about 3 miles of hilly road and it worked fine though the voltage dropped from 27 to 25 volts. Is it ok to use it without the bms whilst discharging and use the bms to charge? If so can I use the voltage of the battery as a guide to when to stop using it and what voltage should that be? It seems to charge to just over 28 volts , that seems to drop on todays experience to about 25 volts after probably 4 or 5 miles. I read the post about testing individual cells but there are only 7 wires as far as I can see in the wiring "ribbon strip" connecting the bms to the battery , should there not be 8? I want to work out wether the fault is the bms or the battery, presumably caused by the short and wether it is worth doing anything about it, eg buy a new bms?
Rob
Rob
