Sr.Agaporni
I am thinking un an urban commuter, based on and old steel frame street bike i bought really cheap (70€). I am thinking in a small rear hub motor (XF08), paired with 6 fet sinewave controller and 14S battery. Some of the objectives are it to be stealth, light and secure to leave on the street without any parts easily stolen. I would like to commute at about 40kmh pedaling without hills, and 25kmh with 7-8% hills. My goal is to stay below the 15kg the whole bike including battery.
I would appreciate some help to improve the idea as much as possible.
That is the bike:
Here is the parts I plan to use:
- Rear small geared hub (Mxus XF08 or similar)
- 6 fet sinewave controller
- 14s battery in a box in the frame, with LCD and buttons on it (lights, PAS level, on/off, etc...)
- No throttle
- No display on handbard
- PAS activated
- Front and rear light connected directly to the battery
I also plan to upgrade some part of the bike:
- Handbar (something more commuter instead of the street bike style)
- Brakes levers with motor-off option.
- Maybe fiber carbon fork, handbar and seatpost to take some weigh out.
- Tyres for something wider for a more secure commuting.
The most important part of the ebike will be the battery case, located in the lowest part of the frame, where I plan to fit the battery, controller and all the switches needed. It should be water resistant and secure locked so I can leave the bike on the street.
My doubts are:
- Can the XF08 hold 500-750w or would the planetary gears self destruct? I will pedal always, and I don't expect that power to be continuous. Maybe I can add a temp probe to the motor to check the temperature.
- Battery configuration, 14s? 13s? 10s?
- Battery case material: crystal fiber, aluminium, steel?
Any other idea, more than welcome.
That is the bike:
- No throttle
- PAS activated
My doubts are:
