Lightning Rods Big Block Motor w/motor frame
DingusMcGee
Laramie, WY
For sale used: the Lightning Rods Big Block Motor is about a 5000 watt BLDC IPM motor for mid frame mount. The current frame width is setup for 73 mm BB shell width. There are 8 spacers that can be removed and then the frame fits about 68mm BB shell width. With the proper spacer thickness you can adjust the frame size to fit anywhere between between 68 mm and 73 mm.
The LR kit came with a #219 chain sprocket mounted on the motor. The motor now has a #410H bike chain sprocket on it. I used the go cart motor chain briefly and then changed to #410 bike chain for the motor chain.
Included is what is in the picture:
Missing from kit are 3 metric flat head bolts that held the chain guard to the motor and the smaller ~26T? #410 Sprocket that was on the DSBBH.
The motor is in good shape but was replaced with a QS2000 V3 for some more power.
Cost: $125.00 plus buyer pays shipping
Hi scianiac,
The motor and frame are still for sale. You are first up.
I see nothing in yet in the EndlessSphere conversations. Are DMs only a reference to Twitter exchanges. I do not belong to Twitter.
Can we use ES conversations?
