My LightningRods build.
Bike: Giant Anthem 2010 medium
Battery: Headway 40152 Cells (5C discharge 2000 cycles) 16S1P 48v 15Ah, 16S 50-100A BMS, 8A charger
Motor: LightningRods 1.0? Pre-order/Kickstarter/Early adopter/Beta tester
Controller: Lyen 124110 12FET
Display: CA3
Lovely bike the Giant Anthem, I estimate the whole bike is 31kg all up (likely will be 32kg when complete).
I had a few little trials with the wiring which are now sorted (pretty much, probably)
Still to do:
Phone charger and mount
Lights
Tune rear derailleur
Re-mount secondary reduction chain guard
Find somewhere for a pump
Pictures!
The Starting bike
Mocking up the battery
Building the battery
Modify the frame (cutting lugs off) so the triangle is as clear as possible
Assembling the bits
Rebuilding the battery (bottom part) as it didn't fit with the motor well
Metal frame (aluminium) to protect and support the battery
Mockup the side covers
Route all the cabling neatly
Ready to ride!
Next stage in its development
http://endless-sphere.com/forums/viewtopic.php?f=28&t=67014&p=1012077#p1012077
Display: CA3
Still to do:
Lights
Pictures!
The Starting bike
Assembling the bits
Ready to ride!
