Greetings!
The goal of this project was to cram as much power as possible into a reasonably small and light package. At 50 kg or 110 lbs, it's not exactly a mountain bike, but it's still far from a full sized dirt bike. And after working on my 2 wheeled inline skateboard project, I wanted to stay away from small power dense, high rpm motors that require complicated reduction drives to get useful torque. That meant a large, low rpm torque monster like the ME4201. Sure, I had to remove the rear fan and cover to make it fit my frame, but it hasn't had any overheating issues yet. Pretty sure that's a good excuse to buy a bigger controller and put more power though it!
[youtube]Z-6v-Xy4HV0[/youtube]
Link to GrabCAD for 3D model:
https://grabcad.com/library/light-electric-dirt-bike-1
Specs:
Frame- custom water jet cut and machined aluminum (no welding)
Motor- ME4201 (3 phase permanent magnet, axial flux)
Battery- 20S 12P Samsung 25R cells (~72 V ~1.8 kWh)
Controller- Kelly KLS7275D
Throttle: Domino
Variable regen: thumb throttle
Fork- Marzocchi 380 C2R2
Wheels and tires- Shinko SR-241 2.75 x 19 on 1.4" pro wheel rims
Front Hub: Hope Pro 4 20 mm axle
Rear Hub: Hope Pro 4 Fatsno 150 mm length 15 mm axle (no rear mechanical brake)
Reduction- 5:1 #35 roller chain
Total mass ~50kg or 110 lbs
I'm still working on what to use for a seat. Ideally I would just buy something off the shelf that would aesthetically fit my frame and make a bracket for it. That would also give me a location to add a cycle satiator and a BMS to simplify my charging setup. So if you guys have any suggestions definitely let me know!
Specs:
Throttle: Domino
