ArtemT said:
Started to design the battery. The aim is the following: engineer 2 batteries of 120 Tesla batteries each, 72V in total. All the batteries will be held together by means of custom holders, printed on a 3D printer (the volume of each holder is approximately 106 cc). Each battery will have a formula 6P20S. Parallel connection is implemented by means of laser cut copper plates, thickness 2mm. At the narrowest point the cross section of the plate will be about 6 square millimeters. The plates will be fastened to the holder on the glue. Every battery will be soldered to the copper with thin copper wire.
I really like the new frame design and your high level pack criteria (20s12p) are good, however I think you've got few critical things wrong
First, Split your pack into two 10s12p packs, connect in series. This ensures you don't have any potential cell level imbalance (or do not require cell level interconnects, more wiring = more chance for issues). It also lets you run the shortest possible battery leads. You could have cell 1 on the bottom of the left side and cell 20 bottom of the right, ensuring the leads to your controller are as short as possible. This is desirable from a controller perspective.
Second, Don't solder 18650's. This has been covered LOTS of times, it's simply not the correct way to terminate the cells. Soldering introduces substantial amounts of heat in an inconsistent fashion. This leads to inconsistent cell performance which will lead to inconsistent cell voltages, a big headache. Spot welded pure nickel is easy, well understood, substantially cheaper/faster than what you're proposing, will keep balance better and can be configured to have the same low resistance as the copper solution. It suffers from less corrosion related problems as well.
Third, I would suggest using subtractive machining rather than additive for your housing. Depending on the material, it's likely that machined solid will be substantially stronger than 3d printed parts, especially over the relatively large distances your pack covers. Here's a simple test example I made the other day:
This was cut on a CNC router in only a couple of minutes and the fit is flawless. This plastic is very easily machined, dimensionally stable, temperature resistant, an excellent electrical insulator. You can easily fix it using course thread fasteners and pilot holes to other pieces to create very rigid structures. Don't bother with the fan cooling. If your cells are getting hot, you either chose the wrong cells or didn't use enough of them. What sort of power are you intending on pulling?
Fourth, your cell layout should be focused on creating A) maximum conductive area between cell groups and B) ensuring that that conductive area is as even as possible across all the cell groups. Your current layout has groups with effectively 1 cell touching and it has groups with all 6 cells touching. This would again over time lead to cell imbalance.
