Hello,
Just recently I finished building my first ebike. My goal was to build a simple single speed bike for short (5-10km) commutes around the city.
Here's what parts I've got from Grin:
- Front G311 Motor
- 20A Sinweave Grinfineon Controller
- 2 x 36V LiGo Battery
- T-Lever Throttle
- G311 Torque Arm
So far I'm pretty happy with the setup. The bike is very light - just ~13kg without the batteries. I weigh about 80kg so the torque is good enough to help start pedalling from a stop as well as climbing moderate hills.
I see that Grin released a new model of LiGo batteries called LiGo Plus. In the description, they say
My questions are:
- Why LiGo Plus is more suitable when using only 2 or 3 modules?
- What might happen if I continue to use only 2 LiGo modules?
- Why is it better to use 4 or more LiGo modules?
- Can I buy an additional one or two LiGo Plus modules and connect them with existing two LiGo modules? Or is it better to keep modules the same?
- So far I charged my two LiGo modules less than 10 times and used them for around 100 km. Two times I discharged them completely but recharged them promptly when I got home. Do you think these modules might still be considered "like new"? Or are they already used and likely hold less capacity so they're not suitable for combining with brand new additional modules?
- Front G311 Motor
- T-Lever Throttle
- G311 Torque Arm
These new LiGo Plus packs are ideal for running ebikes <...> where you want to use just 2 or 3 LiGo modules. They are less stressed and have less voltage sag in these conditions. For large packs (4 or more in parallel) the standard LiGo batteries are still perfectly suited and the most economical.
My questions are:
