If fork dive is a problem, then before you go fabricating a new anti-dive fork you might want to consider installing harder springs in your tele fork and making the corresponding adjustments to your dampening.
Foale's work is well regarded but not followed much in the real world, as in; Nobody uses link forks in top level racing on the dirt or the track. If it worked better they'd use 'em and believe me, they've been tested to death and abandoned by all but the guy who needs something different, not better. Motorcycles rely on fork dive to effect a change in geometry for the different conditions of high speed stability and sharp turns. Motorcycle riders need the forks to extend under power to lengthen the wheelbase and extend the rake to create a stable high speed bike. The same bike, as it approaches a turn, brakes hard and compresses the forks to load up the front tyre, sharpen the steering and shorten the wheelbase. Ideal geometry for entering the turn. Then they get on the gas and repeat.
As a bicyclist you are likely to have less suspension travel and require less fork tube extension under power and less extreme geometry changes under braking as you enter a turn. Solution? Harder springs, maybe progressive ones.
I personally ride on an AMP-Research F4-BLT carbon linkage fork on my MTB and I swear by it, but on the road I can take it or leave it. Don't go down the anti-dive path until you've made the necessary stiffening adjustments to your tele-forks unless, like me, you're a tragic tinkerer and can't leave well enough alone. Yes, I'm the guy who likes different, even if it's not better :?
