edventure
madin88 said:thanks for sharing some pics^^ whats the size of the bearings you will use?
I will install 42/30/7 2pcs for longer lifesspan. They leave enough thread left for brake rotor srews after machining the sidecover. Ceramic would be awesome, but from what i have seen they are very expensive so i ordered FAG / SKF "RS" bearings.
No problem on the pics, I feel I owe it to the community with all the great information I have acquired over the past two years. It has made my building much easier.
I am planning on installing only 1 40/30/7 bearing for three reasons. Whether these are good reasons I don't know.
1: Cost of the two bearings. I could have probably purchased two ABEC 1 bearings for the price of my 1 supposed ABEC5 bearing, so not the best excuse.
2: After looking at the measurements of the motor cover I thought it would be better to leave more support material on the cover, plus if you machine an opening to fit two bearings the backs of the disk brake mount screw holes will be open to the bearing surface. I wish they made a 42/30/10, that would have been my first choice. If this bearing fails too early I can always machine the cover to fit a second bearing.
3: I thought for reassembly and disassembly removing with a single bearing will be much easier.
So are you installing a heavier axle? Will you be incorporating any type of active cooling? Also be curious to see how your two 7mm wide bearing setup works.
Ed
