Maybe you've heard, but bearing has come up with a formula for directly calculating a comparable form of internal resistance which basically means you can directly compare the performance of the underlying cells from one battery pack to another! His explanation is at his thread . Basically, the "standardized" internal resistance has units of millihour or what I've suggested should be named after bearing and that unit's name currently pending(I suggested bearing, but bearing might have a better last name). So, this post is basically to provide a list that directly compares different cells. The formula for a given battery or cell is R*Ah/V and a lower number is better - Using numbers harvested from several sources, here they are. The formula for R = (V_1-V_2)/(I_2-I_1) and those values should be extracted when the battery is half full. Also, the voltage of the battery in the R*Ah/V formula is determined by a "standard voltage per cell" multiplied by the number of cells in series. This standard voltage per cell is the open circuit voltage of the cell when it's 50% full and this will be the same number for a given chemistry. I haven't verified these values yet, but I'm guessing 3.2 volts for lifepo4, 3.7 volts for LiPo and 1.2 volts for Nimh sounds good. So, for example, a 48V battery with 16 in series would have a 50% half-full open circuit voltage of 3.2volts/cell*16cells = 51.2 volts. The purpose for this standard voltage is to ensure that cells and batteries from different chemistries can be compared.
Update: bearing has come up with a new insight - This formula is basically a straightforward way of finding how long a short-circuited standardized cell would take to drain, in theory when its internal resistance remains constant. The higher the C value, the lower the internal resistance and so you'd expect it to completely drain in a shorter amount of time. He is calling this the cell's SDT or shortest discharage time. To convert from millihours to seconds, we just multiply by 3.6.
(units in bearings = millihours)
LiFePO4(Each cell having 3.2 volts):
A123 M1 LiFePO4: 10 milli ohm * 2.3 Ah / 3.2 V = 7 millihours or 25.2 seconds.
Ping V.1 5Ah cell: .065 ohm*5Ah/3.2 V = 101 millhours
(Measured by DoctorBass) Headway's blue cell: 0.009 Ohm * 10Ah / 3.2V = 28.125 millihours or 101.25 seconds
LiPo(Each cell having 3.7 V):
Zippy Flightmax 5ah 20C cell LiPo: 5 milli ohm * 5 Ah / 3.7 V = 7 milli hours or 25.2 seconds
Nimh(Each cell having 1.2V):
Sanyo RC-3600HV NiMH: 4 milli ohm * 3.6 Ah / 1.2 V = 12 milli hours or 43.2 seconds.
Vectric Nimh: 12 mOhm * 30Ah / 1.2V = 30 milli hours or 108 seconds.
Some observations, lead acid batteries couldn't be immediately based on this formula. A much better comparison is their peukert's constant since their internal resistance is exponential with increasing current. Also, you'd notice that the ping has a corrected internal resistance of about 7 times higher suggesting that if an a123 can be called a "30c cell", than a ping cell could be called a 30/7 = 4.2 c battery. But, what determines a "C" rating is more often based on its 85% capacity cycle lifetime rather than its comparable amount of voltage-drop/battery-heating, and the 85% capacity cycle lifetime is dependent on many more factors than simply internal resistance and the heating of the cell and the relationship is obviously not linear / easily-accurately-predictable.
Feel free to chime in with your own battery's measurements or a cell's data! It'd be nice to have a list to which direct comparisons could be made. Basically, to calculate the value, all you need is the voltage(3.2 volts/cell for lifepo4, an arbitrarily standardized lifepo4 voltage to ensure comparability), capacity(in Ah) and the internal resistance when the battery is half full and you're set to go! If you don't want to do the calculation, just provide the above data and I'll calculate it and add it to the list.
