stevo
As a lithium battery ages/degrades, I assume this means that it will hold less Amp hours (e.g a 10Ah battery when new might only hold 9.1Ah after some time/use). But is there also a decrease in operating voltage? For example, I have a 36V Lithium Polymer battery. Its about 1.5 years old and I have put about 5500km on it (on a Crystalyte 408 using a 20A max controller). When its fully charged (and still attached to the charger) its voltage is 42V. However, I recently noticed that as soon as I unplug the charger, the battery's voltage drops immediately to 40V. Is this normal?
Note: around the same time that I noticed this voltage drop behavior, I had also broken the battery wire. The break was pretty close (ie less than 1/2 inch) to where the wire went into the battery and I didn't feel I had enough room to comfortably solder it so I used a 'butt' connector instead.
