LITHIUM BATTERY REPAIR IN TORONTO ONTARIO CANADA
"The battery will be striped and each cell will be cleaned and capacity tested, only cells that pass the test will be used,"
Bad business practice, in my opinion, It might work with quality brand name cells with recent date codes. When you test and re-use cells that "pass" capacity test, you're just putting time bombs into the battery,
Charge them for new cells, and only use the best.
