Lapwing
I was wondering if anyone knows the separator materials used in the commonly used Lithium cells we have done torture testing and have discharge data for?
Headway, A123, ping, Konion, Thundersky, PSI, Lifebatt, K2, Phet, Valence etc.
It seems to me that the separator material is every bit as important as the battery anode and cathode formulation, with respect to safety and durability and internal impedance.
There are an awful lot of different types used.
Hear is a couple of links.
http://www.scitopics.com/Battery_Separator.html
Doc bass experiment with squashed Caterpillar got me thinking about membranes...........
http://www.endless-sphere.com/forums/viewtopic.php?f=14&t=9158&p=141561&hilit=caterpillar#p141561
"The LG Chem cells use a proprietary lithium manganese spinel (LiMn2O4) material for the cathode with additives to improve calendar life under high temperature conditions; an amorphous carbon anode; a ceramic coating on the separator (the safety-reinforced separator, SRS) to minimize potential thermal runaway due to an internal short; and a LiPF6 electrolyte in organic solvents (gel type). "
http://www.greencarcongress.com/2009/01/gm-to-manufactu.html#more
I'll bet beer :? thatTeflon based membranes hold up longer, are more stable and are a lot more heat resistant than polyethylene - but what about all the others?
http://www.gore.com/MungoBlobs/1017/941/excellerator_separators.pdf
