Jimdear2
We are using isolated DC to DC units to charge individual 3 cell stacks to a regulated 3.5 volts in a 50S/3P battery. This means that each cell stack will reach 3.5 volts and basically stop charging and just float. The three cell stacks have been matched as closely as possible for IR and voltage under a fixed load for a specified time, so there is no real variation of nominal cell voltage.
We are wondering what the effect of leaving the charging system powered up long term. Example, plug it in after the pull and unplug it next week end.
We have gotten conflicting comments about doing this. Some state it will cause the batteries to overheat swell up and blow out the rupture disc other say it will be OK and still others the weakest battery will be damaged.
Is there anyone with experience with this type of scenario that can offer comments.
We also welcome anyone's thoughts on this.
