sn0wchyld
I know ive seen a few around the forums but for the life of me i cant find them anymore, and im sure there's others out there that i stil dont know about so,
I'm looking for a motor for my custom frame build... already looked at https://endless-sphere.com/forums/viewtopic.php?f=28&t=68950 too but looking for slightly different things:
~5kw cont / ~10+kw peak
dia no more than about 180mm, <160 ideally
depth no more than about 120mm mounted, ignoring axle (ie motor body and plate its mounted too ideally less than 120mm, sprocket can be in adition to this width)
an inrunner would be preferable for ease of mounting, but either can work
weight - less critical need but less than 6kg would be nice
<$1k
works with the adaptto controllers would be a good bonus (so slower/higher inductance motors preferable)
Edit
+preferably still be able to use regen (ie most rc motors wont fit the bill here)
Most of these are pretty flexible other than the diamiter
some ive considered
John in CR's 2 speed mini monster - already got one of these. main issue is weight to a small extent, and modifacations needed to a moderate extent. Not in production anymore though, and really would like to build more than 1 bike...
Jobys - still in production? realistically too expensive/hard to control too...
revolt 160s - not bad, possibly the one to beat, other than unproven and issues with flux leakage and running noise (coging torque, my rv100pro is the same, has a bit of a whine to it)
the flux leakage is a real pain as it reduces the motors potential somewhat, but also makes it effectively larger dai than it already is given it'll need clearance to conductive bodies.
Big block - again not bad, but bit low on power, both per kg and not quite up to 10kw i think :lol: .
NT power http://nt-power.eu/engine.html
again nice but out of the price range and kinda hard to control.
edit2
Miles found the thread on the transmagnetic motors. tick most the boxes other than a bit short on power by the looks, and unproven.
There's a couple of others that people have used here, if i can find the threads again ill add them to the list (thanks miles!) . Unfortunatly some of those are the ones probably best fitting the price range and power im looking for, but as mentioned i cant find em anymore! if anyone can offer more suggestions of motors of this kind of ilk it'd be great.
<$1k
Edit
some ive considered
edit2
