The PAS is too powerful. I want to be able to fine tune the amount of assist and/or throttle in order to reduce the assist at different pas settings.
If you use the CA for this, you won't be using the assist levels on the controller anymore, because the PAS sensor will now go to the CA, not the ocntroller. The controller will then have a throttle input from the CA.(fi your controller has no throttle input and/or can't operate without the PAS sensor input, you'll have to change the controller for one that does).
Most controllers I've seen use throttle as a full override of the assist level, so it doesn't matter what assist level is chosen, the CA owuld have full input control range of the sysdtem at all times.
Unlike almost all controllers, the CA doesn't need to use assist levels, becuase it's PAS is not on/off--it actually uses the cadence to directly control the assist amount. (while most controllers just turn the assist on at the full amount of the chosen level if you pedal at all, not caring how fast you pedal)
So you just tune the CA settings to operate the system the way you want.
It has three presets you can use to change some of the limits to get a form of "assist level', but it inst' really necessary for most systems / usages. (For my SB Cruiser trike I have setup three speed limits on mine, 5, 10, 20mph, but I don't use them anymore, leaving it on 20, because the cadence control works perfectly well for doing it just like on a regular pedal bike).
I’m also kind of a data geek and tweeker.
In that case, you may want to get the Analogger (or build one from an MCU) to capture all the realtime data from the CA's serial output. You can use that with the Grin Trip Analyzer to get a fair bit of info about your rides and usages to refine your setup.
There is a long thread with info about various versions of the CAv3 firmware and options if you have a lot of reading time.
Here is a link to the now unofficial user guide and other documents and thread index by Teklektik http://www.endless-sphere.com/forums/viewtopic.php?p=571345#p571345 and the wiki http://www.endless-sphere.com/w/index.php/Cycle_Analyst_v3_Setup and the official CAv3 info page...
endless-sphere.com
