Peddling up hill I felt the crank arm a bit wobbly, next I see the bolt fall out and roll back down into a drain
managed to get home nursing the battery with only one crank arm attached must have looked a strange sight! 8)
As I live in the UK only Banfang bolts are available in the USA,
Is there any one standard crank bolt I can use to replace the Banfang or is it specific to bafang.
Just read that once the arms become loose they are pretty much ruined being soft aluminium. do I need to get replacement arms too then?
Thanks
Thanks
