Looks like this topic ran into a dead end :? cause the wind generator turns out to be not very efficient and it's still heavy.
Another source for such a motor would be this one:
http://www.monsterscooterparts.com/...tor-11-tooth-8mm-05t-chain-sprocket-1318.html
but there is no info about KV, diameter or length. Looks like a kollmorgan, but it turns out that the picture maybe wrong and it will be discontinued so the seller can't give any info here
looks like we have to kick out one target specification. So i will stick back to the proposal of toolman
toolman2 said:
http://www.hobbyking.com/hobbyking/store/__17986__Turnigy_RotoMax_1_60_Brushless_Outrunner_Motor.html
-not a bad contender? 58mm case length and $108, rated for 2960w at 7000rpm (crap i know), proly better suited to 1kw at 1800rpm rather than 1.5kw, but there are also countless size choices upwards of this one.
- yes it still needs siliconeing up i spose, but hopefully you can see the value in a motor being 3 or 4 times lighter for the same power
or saving 2 or 3kg?
which fails at the low KV argument, but it's cheap ($108), lightweight (850g) and short. Maybe the following would be an acceptable compromise:
Running this motor at half of it's rated speed of about 7000rpm would be a compromise. It is 230KV stock, I assume that it's delta wound like all stock rc-outrunners I saw in my live, so we could get it down to 135KV if we redetermine it in WYE (by the proven method lebowski once described). This would lead to round about 3800rpm loaded speed at at 37V and 10s lipo. A three-stage reduction to the crank would be preferable to gain a reduction of around 45:1 to the crank.
Using a 50amps max controller we would scratch along our spec of 1.5kw. A stock KU-123 sensorless controller (cheap to get from bmsbattery) has 30amps max and is able to run even my biggest 80-100 outrunner if the traces are beefed up. It may even handle the 50amps target.
Arguments for this motor are:
-high stator pole count (I have no reference here, but it has definitely more than 12 like the early turnigy 80-85, 80-100 and 63-74 motors)
-thin stator sheets (no reference yet)
-big cooling surface due short stator stack, it should be possible to run it enclosed to make it waterproof (took the spec sheets and diagrams of the CPM-90-22-1500 motor as an analogy
http://www.cpmotors.eu/en/downloads/, the controller uses field weakening so the chart is not 100% comparable, i'd like to post the charts here but i'm afraid that would be a copyright violation
-could fit between the standard BB width of 68mm, to keep packaging simple (no reference here either, hobbyking states that it has a 40mm can, which is quite promising)
Cons:
-gas engine-style rotor mount
-needs extra housing
-high rpm
I'm thinking of a box that just fits below the frame just like the GNG drive, but completely enclosed and only 68mm wide, the housing is a heatsink for the motor, the whole unit would weight around 3kg (6.6lbs), dimensions ca. 200x 85x 68mm (7.9x 3.4x 2.7 inch)
