Hi!
I'm trying to find the best motour for my needs... As you all might be aware of, Turnigy SK3 motours are out of stock in all warehouses at HK :/
The famous budget option, SK3 5055 280kv is unavailable, but there's this one, still available in the UK: SK3 - 6374-168kv
http://www.hobbyking.com/hobbyking/..._Brushless_Outrunner_Motor_UK_Warehouse_.html
My question is, can I use this one as a substitution? Based on CalcRC, using 24T pinion and 36T spur with the 168kv motor, would give me about the same top speed as the 280kv motour with 14T pinion and 36T spur.
My setup is going to be a single motour version on 6s (2x8000mAh 3S), 70mm wheels. http://www.decathlon.fr/longboard-bamboo-bauhaus-id_8330718.html
Will i get similar results in terms of torque and range?
I appreciate every feedback!
EDIT: Also on the product page of the 168kv motour, it says "Voltage: 12S Lipoly". Does that mean that it can be used ONLY on 12S, or is that the maximum?
