BossyGoat
10 µW
So basically, the motor started dropping out as I was riding along. Would cut in, cut out and back in again whilst riding. I thought it was a clutch failure on the planetary gears (the motor is getting on for 16years old and has easily covered 15,000km+ and i've never needed to change them) but this is where my issues are now arising. Turns out one of the planetary gears was lets say a little worse for wear and the clutch plate was to put it simply, finished. I replaced those, couldn't see any other issues inside whilst motor was open.
Everything was put back together I still have the same issue, when the bike is upside down the wheel just judders and doesn't spin like its trying to engage but doesn't. Previously whilst riding and it cutting in and out I honestly wouldn't be able to say if it was the same sound or not as I never had to stop the bike to get it to re-engage, just press the throttle sometimes once, sometimes countless times. So I wouldn't know if this was the same noise or not.
One thing I did notice when removing the wheel to take the gears out. I had to unwire it to get it off (there's no plug connector at the wheel, just direct from motor to connector for the controller) whilst removing the electrical tape I noticed a fair amount of green (corrosion) Phase wires seemed fine no indicator of this. Is it possible the hall sensor wires are causing this due to corrosion? It baffles me a little as I can eventually get the thing to work as it should just intermittent rather than just not working. Could it be the corrosion on the wires causing a good connection, then a bad connection? I just want to rule everything out before attempting to find a similar motor which will be my next problem as I don't want to replace it with something that doesn't perform with the high amount of torque these do. Please help
lol
