whereswally606
I am starting this thread to pull together some knowledge about these little packs that I have gathered for myself and learnt from others.
I've been trying to make suitable mounts for these for a while and recently my friend kev came good on printing my latest design in abs 6 times for the 6 batteries I have bought.
My initial idea was to reverse engineer the mount on the charger to get a secure way of slotting them onto a bike mount, without needing to add or remove anything from the batteries so that I could just use the charger it comes with and not void any warranty.
Now I have 4 working batteries and 2 not so working ones. I tried tonight to charge some of the dead cells with a dumb cccv charger and then my intelligent cb86 charger. I managed out of the 10s cells to get 9s charged to 4.10v , the penultimate cell seems like it can't be revived and the second cell had discharged almost to zero after I double checked a few hours later.
I am wondering whether the cells 2a and 2b are really broke other whether the bms which has Nickel strip taps permanently soldered to it is causing the fast discharge or preventing the charge on the penultimate cell.
The cells probably are dead however I will check in 24 hours all the voltages again and then I will take off the bms and have another go at charging and look again at the volts after another 24hrs to see if the self discharge is as bad as with the bms attached.
My hope is that the bms is causing this as it isn't going to be easy to swap out the 4 most likely toasted cells.
As mentioned earlier I have 2 packs which have gone faulty left too long between charges and murdered by their own bms. I may try and use good cells from one to rescue the other and buy 20 single cells from nkon.nl to replenish the remaining case. Need to build my spot welding kit too.
Anyway updates to follow. Will post some pictures of my setup too.
