OCD Garage
A while back I posted looking for info on large format cell packs after my 72v 23ah pack from Grin started only charging to 82.4v and shutting down at 71v.
I have since opened the pack up and found a very nicely build battery pack with a tiny BMS in it. I decided to change it out for a much larger BMS I had bought for another project some time ago. Originally the pack would only charge up to 82.4v when the charger would stop, even when left to balance charge for hours.
After changing the BMS and letting the pack balance charge for a day, then cycling it through use and charging/balancing again, the pack seems to have reached a maximum voltage of 83.9v, I have yet to see how low it will go while in use as I don't like pushing home. I have read that a cheap BMS will only charge up to the level of the worst cell, whereas better quality ones will drain all the cells down to the same level and then charge them all up together. Should it actually come all the way up to 84v or do you think this is it 'back to normal'?
