coln72
Drivetrain will incorporate two-stage gearing - The first chain will be from a front 52T biopace chainring (don't worry, the rest are round :winkto 26T and 42T chainrings (with a rear-style derallieur) mounted on a triple crankset with the cranks cut off (shown tucked just under and behind the bottom bracket on the diagram above). The third chainring of the triple (52T again) will then drive the rear chain, to a 9-speed cluster on the rear wheel. For tackling hillier terrain, I might use ~40T chainring on the final drive instead of the 52T, but I'll have to see how it goes, and how much the motor helps.
Any reason why you are going to a dual stage drive I guess you would call it. Would seem a lot simpler to run with a larger chain ring - 80 tooth or bigger - and run a direct drive to the rear cluster. Do you really need 18 gears and a 10:1 step up (if I've calculated correctly) with a 700c wheel????? We are pulling 60km/h with 63:11 step up with a 406 rear wheel.
Interesting what you said about buckling rear wheels as i have never heard of it. I guess running 16" or 20" rear wheels are an advantage
