paultrafalgar
Magneto-hydraulic Torque Converter Wheel
Imagine a cycle inner tube filled with a fluid (silicone?). This inner tube is installed in a cycle tyre in the normal way. Installed inside the inner tube are a number (20-30?) high performance neodymium magnets. The magnets may (or may not) be connected to each other by cords (nylon?). A pipe connects the inner tube via a valve to a radial tube connected to the hollow hub containing a reservoir of the fluid which is in the inner tube. The pressure of this fluid can be varied from a control on the handlebar. Increasing the pressure in the inner tube slightly expands it thus varying the grip of the inner tube wall on the magnets (effectively a clutch mechanism). At the cycle fork there is a 270 degree arc of magnetic coils that sits close to the tyre for some length around the circumference of the wheel. By digital control, these coils are energised such that they appropriately attract and repel the magnets in the inner tube causing the wheel to rotate.
This sketchy idea is in response to the overall dilemma exercised here concerning how to run electric motors at their optimun speed (for maximum efficiency) while running the wheel at the desired speed which will vary between stationary and say 300 rpm. To execute this design efficiently would be quite a challenge, I imagine.
What do you think?
What do you think?
