Sigma said:Alright so I want to confirm these settings to make sure I put the right values before ordering. So I have a 30S2P each pack is 6cells at 22.2 Volts. With a full charge at 25.2 Volts. (ZIPPY Flightmax 5000mAh 6S1P 25C http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=8586)
Battery type: LIPO
Charge voltage: 126V
Charge current: 10A
AC voltage 110-120 Volts
AC plug: standard US/Cdn plug
DC plug: JST-XH?
Teh Stork said:I'm working on such a charger atm. The only problem is it will be rather unefficient at 110vAC, mine is designed and works at 220-240vAC.
It's a simple, yet very efficient charger. It uses a AVR to sense ZVS (AC directly into mcu is cool), and use either of the two mosfets to chop the AC. A high powered ultrafast diode will maybe be replaced by a another mosfet - but not yet.
It uses a current sensor IC (able to handle 200A) to controll the duty cycle. It adjusts duty cycle based on current feedback. This current sensor can be "re used" as a AH meter while riding.
As of now I've reached a limit on 1300W, magnetics does in theory - and practice stop being very efficient here. 5 minute bouts at 1700W seems to go ok tho.
It's not heavy, all in all it weighs in at just shy of a kg. More power can be squeezed out adding snubbers to fets and driving them to higher frequency.
Power factor, you ask? Well, it's complicated - that's my reply xD. I haven't got the equipment on how bad it is atm - but 85% (given 75V pack voltage on 220VAC grid) of the time it is drawing constant power from the grid. The current drawn looks like a square wave with a inverted sinus on top. A more exotic algorithm could pull sine wave current too. A buck boost converter would enable me to get 0.99 power factor, but at higher components cost.
If this sounds like greek to you and you don't know where to start, I suggest buying something ready made.
voicecoils said:Sigma said:Alright so I want to confirm these settings to make sure I put the right values before ordering. So I have a 30S2P each pack is 6cells at 22.2 Volts. With a full charge at 25.2 Volts. (ZIPPY Flightmax 5000mAh 6S1P 25C http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=8586)
Battery type: LIPO
Charge current: 10A
DC plug: JST-XH?
Having a bulk charger charge to 4.2v per cell is generally bad practice, unless you have full BMS onboard. I would have the bulk charger set to to 124v (4.13v/cell) or 125v (4.17v/cell) to give a margin of safety if cells go out of balance.
Also, JST-XH is not an appropriate plug for your DC battery connection, especially at 10A charge current. That's what the Zippy balance taps use and you need to charge through the main power leads. To connect the pack to your charger, you'll need either the 4mm bullet connectors which you can buy at hobbyking, or change to a different DC power connector such as an Anderson PP45 or SB50.
Good luck!
Sigma said:Your charger sounds very interesting so how much is it going to cost you to build it all, do you have any pics?
Teh Stork said:Sigma said:Your charger sounds very interesting so how much is it going to cost you to build it all, do you have any pics?
Build cost is about 20-30 dollars in fets (could be done for 10 dollars - but with significant heat production and ~10% efficiency loss), 5 dollar mcu,, 4 dollar current IC sensor, 5 dollar pcb, Huge ass toroid - had it lying around ~5-10 dollar, 30meter enammeled AWG18 copper wire (using 5 parallelled strands to get resistance down), 2x mosfet driver 4 dollars, dollar fuse and about a dollar worth of resistors, tactile buttons and capacitors. Working hours, so far; ~10 ish. The project is still on the evaluation-board stage, but has charged my pack successfully some times now.
I plan to implement 3-5 thermistors and a "is the pack in balance" check in the form of a middle point test point. I'm also adding sleep functionality, enabling it to dwell at 1uA draw. Current draw from the battery pack is meant to be done through the current sensor, so the charger will have a idea of how much "fuel" is used.
As for the price once I'm done, not sure - but I'm guessing around 100 dollars would be a ballpark figure. I won't ruin my reputation by sending out a product killing batterypacks - so I plan on 'doing this right' the first time.
It slowly evolves to something like a child of a threesome starring a BMS, Cycle Analyst and a charger xD
Sigma said:Alright good luck to you, would you happen to have an ETA of when yours will be done? lol I dont want to go spend $250 + about $100 shipping on that charger and then find out your selling to everyone on es a week or a month later when I could have waited to get your bad ass charger![]()
