Hyena
Hey guys,
I'm looking for a cheap option to upgrade the heavy and old SLAs I'm currently using.
I've got a 36v 500w golden motor kit but I plan up to mod the controller to run @ 48v. I'd rather go faster for a shorter distance
I use my bike more for fun than serious commuting and would be happy with a range of around 10km.
If I was in the US there's a few other options I'd probably go with, but being in Australia the shipping costs on batteries from OS is probably too high to entertain.
I came across THESE bulk NiMH AA batteries that are supposedly rated at 2800mAh. $98 for 48 seems pretty cheap, for under $200 AUD I could make a 48v 5.4 Ah pack. The only unknown is their C rating, which could be a limiting factor. Is there a rough minimum you'd expect from them ? I've seen some cells only rated at 2C so I guess I'd have to plan for that and anything else is a bonus. If that was the case, is it worth doing if it only puts out 10 amps at best, or should I give it a miss ?
The other thing i need to sort out is a charger. There's no need to balance charge NiMH packs is there ? I've seen 3 wire chargers around the place with the 3rd wire only being for a thermistor, so I'm assuming its ok.
Feel free to nip my ideas in the bud if I'm overlooking something fundamental
