Thomsontouring
🔌 New-ish
- Joined
- Jun 19, 2018
- Messages
- 24
Eight years ago I put together a BBSHD build for cruising the rural back roads on weekends. I scored a V1 Ludicrous controller from a friend's second hand Luna bike. I put in a 17Ah Em3ev battery running a nominal 52v. It's been running fine but after 9000 miles I was noticing a lot of voltage sag. It could easily drop 7-8 volts when given a lot of throttle, but I surprisingly never tripped the BMS. It was just sluggish, especially in the winter. The motor should have been drawing 60A and the BMS in the triangle battery was rated at 35A continuous / 51A burst.
So early this year I ordered an e-moto battery from Amorge, after carefully mocking up the size and shape to prove that I could really squeeze it into my small frame triangle. It took a full 8 weeks to arrive by sea, but the packaging was superb. I got a 35Ah 52V battery because the early Ludicrous can't take anything over 60V. But to ensure I never ran out of amps, I specified a 340A BMS and 14s7p EVE 50-PL tabless cells.
Long story short - I got the battery into the bike and it's a whole different animal. If I'm not careful it will wheely or scratch out on every start. It never exhibited close to that kind of behavior before. It's as if the battery is now pouring in amps where before it was dribbling them. I haven't tested the max speed but it's geared for 43mph unloaded in top gear. With a full battery it should be putting out 3400 watts.
