astilwell611
- Joined
- Aug 23, 2015
- Messages
- 100
Thanks for the response, your mounts look awesome keep up the great work!
Thank you!!!astilwell611 said:Thanks for the response, your mounts look awesome keep up the great work!
Sparrowhawk300 said:Managed to mill a kinetics 206 Vesc heatig sink plate (Squad inspired). I already know that i m loosing the waterproof function of the box....cause you really need air vents ...I actually did it and the wind just blows on top of the vesc thru the lid... probably will add a couple of 50 mm fans at one point, but so far the holes in the lid truly made a difference...Still running on one vesc and one motor , the second motor should be here by the end of the week along with the 2x6s batteries![]()
Been zapping arround for a few weeks with mine and they don t seem to loosen up, but happy that your solution works for you.Jynxbone6986 said:Figured i should update. I ended up roughing up the motor and mount w a dremel cuting shallow parallel lines and put more loctite on. Ive been riding it a couple weeks now and it doesnt seem to loosen up anymore.
Sparrowhawk300 said:Drv Chip blew up in 12 s setup on the bench...2nd vesc acts like has no power...drv going down as well ...was fine on 7snow...they left a bad taste in my mouth...can t affort to keep burning money on the vesc so... i m going different ...should of listen to Squad. Live and learn,
I think on 12 s you are really asking for it on the VescSquad said:Sparrowhawk300 said:Drv Chip blew up in 12 s setup on the bench...2nd vesc acts like has no power...drv going down as well ...was fine on 7snow...they left a bad taste in my mouth...can t affort to keep burning money on the vesc so... i m going different ...should of listen to Squad. Live and learn,
I told You, 2 of my 4 VESCs are permanently fried other two had drv chip transplantsIf it's only drv chip VESC may be salvageable, if You have heat gun You can even replace it Yourself. Those maytech 12S ESCs are bullseye for me, their only downside are breakes, a little to strong and not as smooth as VESC. Other than that, POWERRR, reliability (so far) and sensored function is in my opinion the best that You can find to work with 12S voltage.
Sparrowhawk300 said:I think on 12 s you are really asking for it on the VescSquad said:Sparrowhawk300 said:Drv Chip blew up in 12 s setup on the bench...2nd vesc acts like has no power...drv going down as well ...was fine on 7snow...they left a bad taste in my mouth...can t affort to keep burning money on the vesc so... i m going different ...should of listen to Squad. Live and learn,
they are good up to 8s ...after that is questionable. I will probably try yo change the drv and revive them, meanwhile saving for the maytech, So the brakes are a little strong...i can live with that, probably the noise is a little loud as well...did you use aliexpress? Can you adjust settings ? Man I just wanna ride ...after I got the bug can t handle myself without a board now
) weird!
Sparrowhawk300 said:Thank you Squad for your input! I will certainly do that (contact maytech directly). Those maytech Escs sounds like a dream minus the regen breaking...which doesen t help us that much...i will just miss the FOC of the vesc ....oh well ..."The Rat" delivered the goodies(Mouser), waiting for some flux and then were doing the DRV transplant on the patient.![]()
My 230kv motors are not helping the situation...vesc got really hot ...like BBQ hot on a single setup on 12s. Didn 't die but was waiting for it...Will probably sacrifice some speed and go on 6s only and report back...
I am pretty sure that is what happened too much rpm in short bursts with no load...so watch out for those bench tests at high voltage. Maytech responded back they have the MTES120A-SBEC at 129.00 with tnt shipping and 15.00 for the prog. card, that s is a great price, gonna place an order at the end of the week. Had some issues when removing the DRV chip , was quite hard to melt the solder points, esspecially the big pad underneath ...I hit it with 450 degrees and still wouldn t release...eventually ripped a couple of traces when finnally the solder started to melt ...but last two pins stayed glued and then peeled off...will fix it but can you give some recommendation on removing the DRV with reflow station Squad? Looks like the solder used in vesc has a high melting point ...maybe over 250 C degrees...Squad said:It's commonly said that VESC shouldn't be run on 10-12S with motors above 200KV, probably that's also why drv chip died.
I was running it on 7s and was pretty impressed, there was no heating problem, now i will give it a shot on 6s...it might get hot ...but the track that I use is all asphalt and no hills...should be ok .mccloed said:Sparrowhawk300 said:Thank you Squad for your input! I will certainly do that (contact maytech directly). Those maytech Escs sounds like a dream minus the regen breaking...which doesen t help us that much...i will just miss the FOC of the vesc ....oh well ..."The Rat" delivered the goodies(Mouser), waiting for some flux and then were doing the DRV transplant on the patient.![]()
We have run the VESC's on 8 and 10s with 230 and 245kv motrs without an issue. It seems to me that the VESC's like 10s. Even on 8s I had to run a fan to keep the power from falling off from heat. On 6s the power would drop off quickly because of heat.(I know some people run on 6s fine, though)Those Maytech ESC's are pretty good except for the the brakes, which are pretty much all or nothing, but they are pretty silent. To anyone using the Maytech or FVT 12s 120a ESC: Make sure no throttle input is given on start up. I have fried several of these by accidentally giving a little throttle while turning the ESC on.
Sparrowhawk300 said:I am pretty sure that is what happened too much rpm in short bursts with no load...so watch out for those bench tests at high voltage. Maytech responded back they have the MTES120A-SBEC at 129.00 with tnt shipping and 15.00 for the prog. card, that s is a great price, gonna place an order at the end of the week. Had some issues when removing the DRV chip , was quite hard to melt the solder points, esspecially the big pad underneath ...I hit it with 450 degrees and still wouldn t release...eventually ripped a couple of traces when finnally the solder started to melt ...but last two pins stayed glued and then peeled off...will fix it but can you give some recommendation on removing the DRV with reflow station Squad? Looks like the solder used in vesc has a high melting point ...maybe over 250 C degrees...Squad said:It's commonly said that VESC shouldn't be run on 10-12S with motors above 200KV, probably that's also why drv chip died.
Sparrowhawk300 said:@IceNine, I have attached my motor mounts, I work in aspire so I can only export .ai .svg, .dxf. Can also supply the aspire file, let me know.
Motor Mount:
Motor Spacers and Brackets:
Thank You Jenso!!! Thanks for the inspiration!!!nowind said:Nice Video, like the soundtrack!
Keep on building.
Jenso
